User directory with spouse, parents, children?
Last Post 2011-06-04 01:09 AM by cajazzer. 4 Replies.
Larry DanieleUser is Offline
2009-06-11 02:39 PM
I am building a website for a church that would like to put their member directory online. However, a key requirement is for a user's entry to show their: * Spouse * Parents * Children Is there a module that can handle this "out of the box"? Or will I have to "role my own" (e.g. with the new XMod Pro)?
gbrownUser is Offline
2009-06-11 10:24 PM
I'm doing almost the exact thing. I plan on using Dynamic Registration module from Data Springs and then building User Directory in Xmod Pro. Unless I can figure out how to dynamically add users to roles via Xmod Pro (I'm working on that right now) then I'll do the whole thing in Xmod Pro.
Greg
2009-06-13 05:50 PM
I'm not aware of a module that will do this.  You will have to structure the data so that the familial relationships are captured.  There may be some genealogy related modules that show you how to set up the relationships.
HaloDigitalDesignUser is Offline
2011-02-14 04:47 AM
I am looking to do something similar. What solution did you end up using?
cajazzerUser is Offline
2011-06-04 01:09 AM
I am also implementing the same thing for a church. I am building a dnn module that will allow users to specify other users as part of a family unit as Joseph mentioned. Would love to hear others requirements for this.
DNN nav issue by imran shaikh
