Require Classifieds module
Last Post 2009-05-16 05:20 PM by Joseph Craig. 1 Replies.
sharadUser is Offline
2009-05-16 08:21 AM
I need classifieds module. Please suggest
Pooja
2009-05-16 05:20 PM
You might want to look at Ventrian's property manager. Also, google "dotnetnuke classifieds."
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
