Links
Last Post 2010-03-12 11:15 AM by rajani. 51 Replies.
Page 3 of 3 << < 123
rajaniUser is Offline
2010-01-18 05:09 AM
Thanks sir.It works!!!
2010-01-18 05:12 AM
Are DNN and Sharepoint same? Which is better for CMS?
2010-01-20 12:21 PM
Good Evening Sir.
Pls tell me what is 'SSL settings' in site setting of Admin tab.
Joseph CraigUser is Online
2010-01-20 12:40 PM
SSL stands for Secure Sockets Layer, and is the standard way to send "secure" web pages.  If you've ever seen https instead of http, that means that the site you are viewing is sending the pages to you securely using SSL (the https).
The SSL settings allow you to specify which pages on your site are to use https rather than http.
With reference to your other question, DotNetNuke is not the same a Sharepoint.  They do have similarities, as well as differences.
2010-01-27 11:22 AM
Good evening sir.
I want to create user manual for my shopping cart site.In user manual i want to add installation steps of shopping cart software.can i write dnn installation steps in it or only shopping cart steps.?pls help me .
Thank you.
2010-02-11 12:26 PM
Good evening sir,i have changed the dotnetnuke.ico and favicon.ico icons with my icon for changing the dotnetnuke icon on tag bar.But it display change only in mozilla firefox.Internet Explorer does not display this change.how can i fix this problem?
Pls help me .
thank u.
2010-02-11 02:17 PM
IE is caching your favicon.  IE is slow to get new versions of favicons.
If you have changed the icon on your web you see an old icon (or no icon) in your browser, refresh the page or clear the cache.
Clearing the cache is the most likely technique to work reliably with IE.
2010-02-12 10:30 AM
Thank you sir.It works!!!!!!!!!!!.
2010-02-25 10:04 AM
Good Evening sir,thanks for previous all reply.
I have a problem.I have a shopping cart site 'webstoreshoopping cart' .I have added parent portal for site as'golden...'. Currently i m using default skin.can both sites use same skin file?
In 'webstoreshoopping cart' a:hover{color:#556B2F; text-decoration:underline;} property of skin shows result but in parent portal site it shows text-decoration:underline; and color change from #556B2F to white. how does it change?
  Pls check  following links-
 main site--http://webstoreshoppingcart.com/Cat...fault.aspx
parent portal--http://golden.s20.dotnetsql.com/AdminPages/Category/CategoryMessage/tabid/229/Default.aspx
2010-02-26 12:37 PM
You may find this tutorial helpful: Troubleshooting DotNetNuke Skins
When I used the Web Developer's Toolbar to look at the CSS for your two sites, I found that both pages had a large amount of "embedded styles."  Those styles are different.  That is why the two pages are different.
I suspect that you have included styles either in your skin file or in the page.  You'll want to remove them.
2010-03-12 05:28 AM
Good morning sir.
I want to rename the my parent portal from 'golden.s20.dotnetsql.com' to 'webstoredemo.com'.How do i do this pls help
me out.It's urgent!!!.
thanks.
2010-03-12 11:15 AM
I have another question,in paypal integration for payment i have used
[script removed]
RE: Deploying dnn by Sameer
Just sent it.
