windows authentication for intranet
Last Post 2006-09-04 08:32 PM by mike mogensen. 0 Replies.
mike mogensenUser is Offline
2006-09-04 08:32 PM
I cannot get this to work despite several attempts and much googling. Is there a step by step guide anywhere?
I have ->
uncommented the HTTP authentication module.
set authitication mode to windows. (with and without forms, with and without impersonate)
set no anonymous on windowssignin.aspx
Thanks.
DNN nav issue by imran shaikh
