Invalid file extensions
Last Post 2009-01-23 12:27 PM by EnhesaIT. 4 Replies.
EnhesaITUser is Offline
2009-01-13 11:54 AM
Hi Everyone,
Is there any way from where i will get all the file extensions which are valid in Dotnetnuke 5.0 while packging our module. Actually i i crete a zip file for my module and try to upload it into the DotNetNuke 5.0 framework it shows me errors message INVALID FILE EXTENSIONS . then just with my guess i delete some files and then again try but it is nota good way. Could you please help me on this.
Thanks a lot
Akshay
2009-01-13 12:29 PM
Also if you tell me the tool from which i can pack my module easily or create a zip file from them.
2009-01-14 12:33 PM
This is a guess, but ' invalid file extensions' may be referring to the file types that you are allowed to upload to your DotNetNuke installation.
To check this, go to:
HostSettings / advanced settings / other settings
And check the list of allowable file extensions
2009-01-14 01:48 PM
ok I don't think it is related to the above that I mentioned.
I have just tried to install a 3rd party module in DNN5 and get the invalid file extensions error.
When you receive this error tick 'Ignore File Restrictions'
It will provide a warning - you then need to click on browse again + select the module zip file to install.
2009-01-23 12:27 PM
Its working now . Thanks a lot for your help leesykes.
