Tree module
Last Post 2006-01-03 08:52 AM by Lee Sykes. 1 Replies.
sandi sandiUser is Offline
2005-12-27 02:28 PM
Hello All,
Thanks for your help till now and hope you are enjoying Christmas holidays.
I want to develop a tree structure design in my portal. So can you please tell me if such module is exists already or I can take reference from anywhere. Any link or docs or video will help me.
I feel I will explore more...
I want to show the user name and its child references. Like A have two child references as B & C. Then B may have D & E, and C may have another one or more child references.
Now I want to show A on top and ten bellow B & C as tree structure.
Thanking you,
Sandi
2006-01-03 08:52 AM
Hello Sandi,
Happy New Year!
You may find a source of inspiration by looking at www.speerio.net
I used a Treeview module for creating a sitemap of a DNN v2.2 website, which is available for download from the speerio site.
Check out the downloads page: http://speerio.net/Default.aspx?tabid=334
/ Registered Users Downloads folder /
/ Modules for DotNetNuke /
/ Sitemap
You may also find similar modules on Snowcovered.
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
