Setting up Child portal
Last Post 2010-05-13 01:16 PM by Joseph Craig. 6 Replies.
Lokesh SharmaUser is Offline
2005-12-23 07:19 PM
Im new to DNN so need your advice:
I have created a parent portal (www.classicitsolutions.com), everything seems to be working fine.
Can u pls advice how to setup a child portal on DNN ????????
Once we created a child portal on DNN then how to setup the domain name (sub-domain) for that ?????
I know little bit but don't wont to make a mistake. So can you pls advice ???
Also is it possible to have 2 portals both parent on DNN pointing to different domain name for e.g
1. www.classicitsolutions.com
2. www.classicconsultancy.com
I hope im able to explain what im looking for ??
Regards
2005-12-24 10:25 AM
This is a full article, I will try to summarise what to do and I will create a full tutorial of it for release in a future issue.
Child Portal:
WIll be something such as: localhost/mainwebsite/testskinportal
(You can test this out on a localhost installation before attempting it on a live installation)
To create a Child Portal:
Log in as Host
Go to Host menu / Portals
Click on Add New Portal
Click on Child radio button
Add to the link the name of the Portal you would like eg: localhost/mainwebsite/testskinportal
Enter the rest of your details and an admin username that you would like to create for this portal
Click on Create Portal
It will automatically log you in to your new portal as Host
To create a portal that points to a domain name - when you create the portal select Parent rather than child and enter the domain name you require.
The second part of your question is related to portal aliases:
- If you want to add another domain name you can use the portal aliases section
go to admin menu / site settings, scroll down
Click add New HTTP alias
Add the additional address - do not use http:// - just use www.myaddress.com
Pointing 2 domains using this method is not a good method however as Google will read the sites as 2 separate sites that have dupliacte content. - We discuss this in the mp3 interview with Jeff Smith and the solutions / workarounds you can implement - listen to the interview here:
DotNetNuke Search Engine Optimization
Hope this gives you some starting points to experiment with, thanks
bondjimbondUser is Offline
2010-05-12 05:45 PM
This may be a dumb question, but I've had trouble finding the answer.  I'm assuming it's "yes", but I don't want to commit to something until I have confirmation...
When I set up a child portal, do I get to create a new page structure (new menus, new layout, etc.)?  Or am I bound to the parent portal's structure?  Am I able to treat it as an entirely separate site, but with access to the same modules and within the same domain as the parent?
Thanks much for any clarification you can give me.  I don't have access to my company's admin privileges, so I can't play around with it myself, but I have to make recommendations about whether or not to use DNN for one of our projects.
2010-05-12 05:45 PM
2010-05-12 05:54 PM
The answer is yes.  Both parent and child portals are separate websites, sharing resources like modules and skins.
The main difference is that child portals can be addressed with the parent's domain name.
Child portals can also have totally separate domain names.
2010-05-12 06:46 PM
Thanks for the help!  I have one other related question... as child portals and parent portals share modules, is the child portal's use of the module bound to the parent's?  For example, I plan to use the Forum module in the child portal, while the parent portal already makes use of it.  Can I create forums and host discussions on the child portal, completely apart from those in the parent?
2010-05-13 01:16 PM
Yes, the modules instances in one portal should be separate and distinct from instances in another portal.
DNN nav issue by imran shaikh
