Enlarged Image ‘popup”
Last Post 2008-11-27 02:38 PM by Joseph Craig. 1 Replies.
ollepUser is Offline
2008-11-27 09:40 AM
Dot Net Nuke:
Is here a standard DNN Module to show enlarged images, either by clicking of just hovering over a thumbnail – or similar link?
I just put up some screen-shots on this page:
http://www.goldcoastwebwiz.com/dotn...fault.aspx
But they take too much space, and are still not properly readable.
How can I leave them smaller, (thumbnail size if needed) and have them pop up as a good size image when hovered over or clicked?
Are there one out there already?
Cheers
Olle…
PS. I've done someting in Flash here, but that's a bit of work if it is 1 or 2 images only.
http://www.q1accommodationsurfersparadise.com.au/images.html
2008-11-27 02:38 PM
It isn't a standard module, but I've been using LiveContent from Mandeeps.com. You might want to look there.
