Common Shopping Cart for all Portals
Last Post 2008-10-31 05:31 PM by Lee Sykes. 1 Replies.
Aditya ChallaUser is Offline
2008-10-29 07:19 PM
Hi!
I am going to have one parent portal and a number of child portals. Each child portal is going to be owned by a different company. They are going to configure their products and put them for sale on their corresponding portal.
However, the final Shopping Cart and Check Out is desired to be the same for all child portals. I want the Shopping Cart/Checkout to be on the parent portal. This helps me allow the users to buy various products from various portals in a single payment.
Do you think you have a solution for this?
Please help me. This is a very important functionality that I need.
Thanks & Warm Regards,
Aditya
2008-10-31 05:31 PM
hello,
I am not aware of a store module that does this, however I would contact the store module developers directly and see if it is possible to set this up within their store modules. For a list of the common store modules have a look at the e-commerce section of the module directory.
Hope this helps, thanks,
