Can't add custom module - help please
Last Post 2008-09-28 03:05 PM by Joseph Craig. 1 Replies.
gzhuUser is Offline
2008-09-28 01:41 PM
I am trying to create a module using Linq in VS.net. All goes well and my control builds in VS. I am able to create a module definition in DNN and link it through to my control. Unfortunately when I try to add the control to a web page it bombs out with the below error. It appears to be a compilation error but I dont know what has gone wrong. Can some kind soul help a newbie out.
Cheers
Geoff Scott
Error: FacPatients is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: External component has thrown an exception. ---> System.Web.HttpCompileException: External component has thrown an exception. at System.Web.Compilation.AssemblyBuilder.Compile() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.Skins.Skin.InjectModule(Control objPane, ModuleInfo objModule, PortalSettings PortalSettings) --- End of inner exception stack trace ---
2008-09-28 03:05 PM
There's not enough information there to help. If you look at the event log for your site, there may be more.
Also, you get this the first time you try to place the module on a page?
DNN nav issue by imran shaikh
