uploading wmv files to older version 4.0
Last Post 2008-07-29 12:55 AM by Joseph Craig. 1 Replies.
EllieUser is Offline
2008-07-28 04:30 PM
Hello,  I'm a nubie at this and have gone in under host and added the ability to upload wmv files. However, when I try to upload it will not complete without and error message or page not displayed.  Is there a file size limit or something I don't know about preventing this? Thanks for any suggestions!
2008-07-29 12:55 AM
Yes, there is a file size limit in web.config, and it is probably set to 8 mb. You can change it by editing web.config. Just search for "8192" and you'll probably find the line quickly.
