How To Change Admin Skin Only ?
Last Post 2008-07-29 12:58 AM by Joseph Craig. 1 Replies.
Saqib AzharUser is Offline
2008-07-28 03:31 PM
Hi There
Please Open This: http://img519.imageshack.us/img519/6722/screenev9.jpg
If you see that its not fitting in the screen, How can we increase the Width of this container ? by defaults its comming.. or how can we change the skin of admin pages ? we need to increase the width.
Hope you got my point
Looking forward to hear from you
Many Thanks
saqib
2008-07-29 12:58 AM
You can change the Admin skin using either host or admin settings, depending on how you want to change things. But, remember that the admin settings will transfer to other "admin" type pages on your site. You might want to make a full-size skin that matches your site for better results.
DNN nav issue by imran shaikh
