In/Out Board
Last Post 2008-07-03 10:10 AM by Sergey. 5 Replies.
boothUser is Offline
2008-06-12 04:26 PM
I am looking for a DNN module to replace the old fashioned In/out board.  Any Suggestions
2008-06-22 02:35 PM
I'm not aware of one.
2008-06-22 02:43 PM
But ... after 20 seconds of thinking you probably could do this nicely with the User Defined Table Module.  Use of this module is covered quite nicely here: User Defined Table (UDT) DotNetNuke Core Module.
I would create a list that has these columns:  Name, In, Out
In and Out would be true/false and be represented by radio buttons.  Or just make one Status column.
You could give everyone the ability to edit the module, so they could change their In/Out status.
If, instead,  you wanted to create a simple module for this, that would be a fairly easy thing to do.
If you want to create a module and don't have the resources or know how to do it, I recently discovered this site - www.freedotnetnuke.com.  The offer to create modules for free.  I have no idea who they are or what their game is, but if might be worth a shot.  (I would, though, probably want to see the source code before installing it on my site!)
SergeyUser is Offline
2008-07-02 09:25 PM
Joe
Have just found this article about our site (freedotnetnuke.com). I understand your worry, but we do no create big modules for free. We can create small modules for 2-5 hours of our work. It is like Ads for our service. We are DotNetNuke developers and looking for more work in this way only. Free modules is only possible to say community about us
Sergey
2008-07-03 01:43 AM
Thanks, Sergey!
I'd just come across your website, and thought that the particular issue was quite suitable.
2008-07-03 10:10 AM
Joe
Thank you very much for your comment. We will do it in the best way ;)
In generally it works, because we already have 2 new clients. Its not commercial information, because i think each quality developer will find more clients Only different ways for search.
Sergey
