slevino Posts:
01/21/2013 9:00 AM |
I ran through a bunch of module updates this morning on an older site (6.2) and now I'm getting an error "an error has occurred" on the website. I can't log in to turn off the module (I'm not using it anyway) but I have FTP and SQL access. Is there a way to remove/deactivate the module through either of those? The log shows the following error: DotNetNuke.Services.Exceptions.ModuleLoadException: Could not load file or assembly 'DotNetOpenId, Version=2.4.2.8248, Culture=neutral, PublicKeyToken=2780ccd10d57b246' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515) ---> System.Web.HttpParseException: Could not load file or assembly 'DotNetOpenId, Version=2.4.2.8248, Culture=neutral, PublicKeyToken=2780ccd10d57b246' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515) ---> System.Web.HttpParseException: Could not load file or assembly 'DotNetOpenId, Version=2.4.2.8248, Culture=neutral, PublicKeyToken=2780ccd10d57b246' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515) ---> System.IO.FileLoadException: Could not load file or assembly 'DotNetOpenId, Version=2.4.2.8248, Culture=neutral, PublicKeyToken=2780ccd10d57b246' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515) File name: 'DotNetOpenId, Version=2.4.2.8248, Culture=neutral, PublicKeyToken=2780ccd10d57b246' ---> System.NotSupportedException: Cannot subset Regex. Only support if both patterns are identical. at System.Net.WebPermission.IsSubsetOf(IPermission target) at System.Security.PermissionSet.IsSubsetOfHelper(PermissionSet target, IsSubsetOfType type, IPermission& firstPermThatFailed, Boolean ignoreNonCas) at System.Security.PermissionSet.IsSubsetOf(PermissionSet target) at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission) at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission) at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) at System.Reflection.Assembly.Load(String assemblyString) at System.Web.Configuration.CompilationSection.LoadAssembly(String assemblyName, Boolean throwOnFail) at System.Web.UI.TemplateParser.LoadAssembly(String assemblyName, Boolean throwOnFail) at System.Web.UI.TemplateParser.AddAssemblyDependency(String assemblyName, Boolean addDependentAssemblies) at System.Web.UI.MainTagNameToTypeMapper.ProcessTagNamespaceRegistrationCore(TagNamespaceRegisterEntry nsRegisterEntry) at System.Web.UI.MainTagNameToTypeMapper.ProcessTagNamespaceRegistration(TagNamespaceRegisterEntry nsRegisterEntry) at System.Web.UI.BaseTemplateParser.ProcessDirective(String directiveName, IDictionary directive) at System.Web.UI.TemplateControlParser.ProcessDirective(String directiveName, IDictionary directive) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseReader(StreamReader reader, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseInternal() at System.Web.UI.TemplateParser.Parse() at System.Web.UI.TemplateParser.Parse(ICollection referencedAssemblies, VirtualPath virtualPath) at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType() at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider) at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at DotNetNuke.UI.Skins.Controls.Login.b__1(AuthenticationInfo a) at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext() at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext() at System.Linq.Enumerable.Any[TSource](IEnumerable`1 source) at DotNetNuke.UI.Skins.Controls.Login.HasSocialAuthenticationEnabled() at DotNetNuke.UI.Skins.Controls.Login.OnLoad(EventArgs e) --- End of inner exception stack trace ---
