Subject: iHostASP
Page 2 of 2 << < 12
David Lawrence
10 Dec 2009 6:04 AM
I second the thanks. As a user of the cheapest package I've found it relatively easy to set up and maintain over the last couple of years but oh the speed - or rather the lack of it. I can no no longer put up with a home page that can take up to 30 seconds to load. As someone observed above, people are not going to wait that long for your page to appear - they're gone, and with them their business.
GregN
14 Jan 2010 10:59 AM
I have about 30 sites on an ihost reseller package. Most common complaint is speed. It's a mixed bag. I've learned to optimize the speed of the sites (thanks to information on this site) and have set up my own pinging software to keep the sites active. Get that done and ihost works fine but it's still not the fastest thing on the planet. I have a couple of sites on databasemart.com that are faster right out of the shute (for $3.99 / month!) but don't plan on DNN specific knowledge and support.
Page 2 of 2 << < 12
Folder permissions by saintX
That will work.
