Subject: Netcetera
georgi
02 Jul 2006 5:59 AM
STARTER Package 2005
Disk Space: 500 MB | Bandwidth: 1 GB  | 100 POP3/IMAP Email Accounts | FrontPage Extensions | Stats | Webmail
The Starter Package is aimed at those who are wanting a cost effective presence on the internet. Should your needs grow you can upgrade your account at any time, all aspects of which can be configured via our unique control panel interface.
£30/pa or £3/pm - FREE Setup
More information on the STARTER Package 2005 STARTER Package 2005 - BUY ONLINE NOW
  HOME Package 2005
Disk Space: 1 GB | Bandwidth: 5 GB | ASP | ASP.NET | ODBC | PHP | 1000 POP3/IMAP Email Accounts | FrontPage Extensions | Stats
The HOME Package is ideally suited to the small business and home user alike, including everything needed to get your organisation on the Internet quickly and hassle free. Should your needs grow you can upgrade you account at any time, all aspects of which can be configured via our unique control panel interface.
£60/pa or £6/pm - FREE Setup
More information on the HOME Package 2005HOME Package 2005 - BUY ONLINE NOW
  DEVELOPER Package 2005
Disk Space: 4 GB | Bandwidth: 10 GB  | ASP | ASP.NET | PHP | ODBC | Up to 10 Sites Per Account |  FrontPage Extensions | Stats
ASP.NET hosting is now available to all! The DEVELOPER Package is ideally suited to the web developer, including everything needed to develop data-driven web sites.
£100/pa  or £10/pm - FREE Setup
More information on the DEVELOPER Package 2005 DEVELOPER Package 2005 - BUY ONLINE NOW
  COMMERCE Package 2005
Disk Space: 6 GB | Bandwidth: 20 GB |  ASP | ASP.NET | PHP | ODBC | Database |  FREE SSL Certificate & IP Address | Up to 20 Sites Per Account | FrontPage Extensions | Stats
The COMMERCE Package is ideally suited to the business or developer, including everything needed to get develop data-driven eCommerce sites.
£180/pa with FREE RapidSSL Certificate or £18/pm - FREE Setup
More information on the COMMERCE Package 2005 COMMERCE Package 2005 - BUY ONLINE NOW
  RESELLER Package 2005
Disk Space: 10 GB | Bandwidth: 40 GB  | ASP | ASP.NET | PHP | ODBC | Up to 200 sites per account | FrontPage Extensions
The RESELLER Package is aimed at those wanting to cost-effectively develop sites for their own clients, this Web Package offers you a massive 10GB of space PLUS the ability to map an unlimited number of Virtual Domains within your area - giving you full domain ability e.g. http://www.clientsname.com/
£450/pa or £45/pm - FREE Setup
More information on the RESELLER Package 2005 RESELLER Package 2005 - BUY ONLINE NOW
