Subject: 1&1 Hosting
JodyWood
11 Jan 2008 1:54 AM
Does anyone have any experience setting up a DNN site through the web host 1&1 - http://www.1and1.com/? I am considering using them as my web host for my under development DNN web site. I am hoping to obtain insights that I can learn before hand before I make my final decision. I appreciate your feedback.
Jody Wood
11 Jan 2008 1:58 AM
I looked at them when I first started out in DotNetNuke. The problem is that they refuse to set the correct permissions to run DotNetNuke in a shared hosting environment.  To correctly run DotNetNuke with 1&1 you have to get a dedicated server. If you are looking for hosting of DotNetNuke I would recommend you go with a hosting provider who is experienced with DotNetNuke, it will save you a lot of pain in the long run.
RE: Database error by derpir
