Subject: How to Deploy DNN Project
xsameer
27 Nov 2007 4:15 AM
Hi.
I am sameer and was helped very much with this forum. so now wanted to know the technical issues with Deployment.
Scenario : I have developed the website In my localhost and now I wanted to upload or deploy it to the server, so to acheive this please assist me in process to make my site work over the Internet.
and If am deploying the site to the server, how server should be configured. is there any specific process (like installing DNN on the server) or installations to be done.
Hopefully expectiing a best Guide to take my work on and on.
27 Nov 2007 9:21 AM
Try these tutorials:
Forums > Hosting > DotNetNuke® Hosting Providers > How to Deploy DNN Project
RE: Cannot view host filespace using text/html editor by NonStopMark
Hi Joe, The problem has gone away. May have been a caching issue. Thanks for posting. DNN : ht...
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
