Subject: HOSTING PROBLEM
frz1
05 Jul 2007 2:47 AM
Which company will be better for hosting
I have made my site using these technologise
  1.  DOTNETNUKE 4.5.3
  2. SQL EXPRESS 2005
I have two links AND CHOOSE FROM THESE TWO
www.casycgi.com
www.powerdnn.com
What will be the better option from these two????
need help!
RE: Database error by derpir
