| RE: Problem in front end by leesykes |
| The first place I would look is in your skin code, the code for the ControlPanel should look somethi... |
| RE: Registration Module - Title Repeating Twice by leesykes |
| Yes, most of the work has been already done for you in the free skins that are available on DNN crea... |
| Problem in front end by kaustav_kar |
| Hi,In my website which is in Dot Net Nuke is showing the control panel in the front end in all the p... |
| RE: Registration Module - Title Repeating Twice by jncraig |
| Creating a custom container isn't necessary!Lee has been including a "transparent, no title" skin wi... |
| RE: Registration Module - Title Repeating Twice by Tripytaka |
| Leesykes, Thank you for your prompt reply. I have un-ticked the display container setting and it ... |
| RE: Free website monitor by inetwiz |
| Another free site monitor website is http://www.contentsitemonitor.com This site allows to you to pe... |
| RE: PowerDNN by jazzylily |
| I have spoken with Tony Valenti today. He seems like a nice man and has assured me that he will loo... |
| RE: Any Idea On A Module For The Following? by leesykes |
| I haven't seen anything that will do this in one area. Looks like you may need a custom module for t... |
| RE: Google Maps Tutorial Website by mgordon |
| Hi,I took a look at your site. It was not bad at all.My only suggestion would be to somehow delinea... |
| RE: PowerDNN by DavidWSnow |
| I have been with PowerDNN for about a year now. No performance degradation issues.They do seem to go... |
| RE: PowerDNN by mgordon |
| JazzLilly,Please let us know if your issues get resolved. I'm getting ready to start a contract for... |
| RE: Any Idea On A Module For The Following? by mgordon |
| OK, thanks Joe. Anyone else have any ideas? Thanks! Mark |
| RE: Any Idea On A Module For The Following? by jncraig |
| Yikes! I guess my answer is no. I don't know of a module that will meet your needs on this one. |
| Hi Joe, No, you were answering someone else's question. Please re-read my question at the top. ... |
| RE: Changing top navigation bar item by jncraig |
| Great! |
| RE: Creating anchors across modules by jncraig |
| I have had no problem inserting anchors. If you want to place anchors at the top or bottom of modul... |
| That's interesting, I have never seen that before!But, after adding the user accounts module to the ... |
| RE: PowerDNN by MobileNow |
| Hi JazzLilly,Is there a phone number I can reach you at? I'd like to talk with you about your issue... |
| RE: Creating anchors across modules by leesykes |
| it should be possible to add anchor points anywhere on a page, all you need to do is work out how to... |
| RE: Media in internet explorer. by leesykes |
| if you are only adding images to the page, I would simply use the text HTML module and this should g... |
