Subject: Portal Web Hosting
05 Sep 2005 3:48 AM
http://www.portalwebhosting.com/
  Free LiveStats.XSP Log Analyzer
  Free DotNetNuke Installation
  Free Module Installations
  Free Domain Transfers
  Toll-Free Phone Support
  3 Months Free (select "annual" in cart for discount)
Web Space: 250 MB  DNN 2.1.2 only
 Parent Portals: 1  Child Portals: Unlimited
 DB Type: Access  Email Accts: 25
 Web Space: 600 MB  DNN 2.1.2 or 3.0.13
 DB Type: MS SQL  DB Space: 150 MB
 Email Accts: 50
 Web Space: 1000 MB  DNN 2.1.2 or 3.0.13
 Parent Portals: 2  Child Portals: Unlimited
 DB Type: MS SQL  DB Space: 300 MB
 Email Accts: 100  Dedicated IP: 1
 Web Space: 1500 MB  DNN 2.1.2 or 3.0.13
 Parent Portals: 3  Child Portals: Unlimited
 DB Type: MS SQL  DB Space: 500 MB
 Email Accts: Unlimited  Dedicated IP: 1
KevinDonahoe
29 Oct 2005 11:12 AM
Excellent customer service.  They go the extra mile to keep customers happy and sites up and running!
DSCarson
22 Apr 2008 2:25 PM
As a DNN virgin I quizzed the Support team about a number of things and ultimately decided to purchase a Business Account.
While the setup was not immediate (as I saw with some other providers) it was pretty quite.
My site has been up and running for a few weeks now and on the whole I am happy with the performance and services. The only down side is the lack of documentation on how to configure your portal (which is still pretty raw) and the mailbox settings - which is straight forward once you know how but a bit of a leap otherwise.
I am assured that propert documentation and Flash tutorials are on the way and once in place I would have no hestation in recommending them.
Thier support team respond quickly and know what there product very well.
If I had to score them I would say 8/10. Good service, functionality and performance. Could do better with documentation for 'newbies'
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo It's always better to use the busin...
RE: Query regarding clearing cache by jncraig
Query regarding clearing cache by kaustav_kar
Hi,In my site which is in Dot Net Nuke to clear cache I want a button. Is there any code with the he...
MY FIRST DNN SITE by mattshortland
hello I am just working on my first dnn site and wondered what you all think? http://letcombebass...
New CSS site feedback please! by dp6ai
I've just designed my first CSS site. I'm not sure how well it works because the client was so keen ...
