Subject: Server Intellect
10 Aug 2005 4:19 PM
Server Intellect, previously known as Easerve, do not specialise in hosting DotNetNuke websites, but they offer the services required to run a DotNetNuke website.
http://www.serverintellect.com/
You can select from:
  • Shared Hosting
  • Virtual Servers
  • Dedicated Servers
Shared Hosting
Is controlled through the Helm Control Panel, where you can create your MS-SQL databases etc.
You can access your MS-SQL database using Enterprise Manager.
Tier One
Features Overview
Single Website
500 MB Space
10 GB Bandwidth
1 MSSQL Database
250 MB SQL Space
ASP/ASP.NET
$14.95 Per Month
Tier Two
Features Overview
3 Independent Websites
2000 MB Space
30 GB Bandwidth
3 MSSQL Databases
750 MB SQL Space
ASP/ASP.NET
$39.95 Per Month
Tier Three
Features Overview
5 Independent Websites
3000 MB Space
50 GB Bandwidth
5 MSSQL Databases
1250 MB SQL Space
ASP/ASP.NET
$69.95 Per Month
10 Aug 2005 5:11 PM
I can highly recommend Server Intellect. I have one website with them and several clients who have subscribed to their services, all using the Tier One Package.
I have not had any problems with installation, speed, service, support etc. and found it easy setting up DotNetNuke sites using the Helm control panel.
But, I have not requested any specialist DotNetNuke support and they do not claim to offer any support for installing DotNetNuke.
I have been very happy with the service so far and have not come across any problems.
Recommended: 10
Support: 9
Performance: 10
Value For Money: 9
johnyG
17 May 2006 7:11 AM
I have this site on serverIntellect:
http://www.hapoel.info/site/
I'm very pleased.
speek
19 Oct 2006 9:51 PM
Can anyone direct me regarding the switch from Prepropagation Support to live site while running DNN 4.3.5? When hitting the url for the site, I'm prompted for the preprop address login and password. Do I have to change something in the db? thanks in advance stacey
20 Oct 2006 8:11 AM
I haven't used Prepropogation Support on Server Intellect, I would suggest you send a held desk ticket to Server Intellect to ensure it is setup correctly.
