Subject: Multiple Parent Portals with seperate email accounts on shared hosting
Karan Jasjit Singh
03 Feb 2010 5:20 PM
Hi there,
I have a windows shared hosting account with Mochahost. I have installed DNN website on their server. Now, I
want to setup multiple parent portals for each domain name I have. Each domain is a different website, obviously,
so I need to setup separate email accounts for each domain, but they all should point to the same DNN website so
that I can use the multiple parent portal feature of DNN.
Now, the support staff tells me that I can add Domain Alias for each domain name to have multiple parent portals
on the same DNN installation. I tried that and it works fine. But I cannot edit the domain alias and create email
accounts (because its an alias) - they just point to the same mail account at the parent dnn website. All the mail is
redirected to the parent DNN website mail account as well!
They are taking too long to help me get this setup so can someone please suggest me some solutions for this so
that I can forward it to them and get my portals (with separate email accounts) setup soon.
To summarize, i want
1. Setup multiple domains to point to the same DNN installation so that i can have multiple parent portals, and
2. Setup email accounts for each domain separately (do don't want to add each domain as alias).
Thanks for your help.
Karan.
Len
05 Feb 2010 8:48 AM
Hi Karan,
Do you know which control panel program your host is using?
IXWebHosting.com has an Edit button next to the Domain Alias. That is where I go to setup Email for my Parent Portals.
Best Regards,
-Len
Karan Jasjit Singh
05 Feb 2010 11:47 AM
Hi Len, thanks for your reply. They are using Parallels Plesk control Panel. There are not email account setup options for a Domain alias. If you "Create" a domain, then you will get the mail accounts options.
Still, do you think having a statis IP address and pointing all the domains in the DNS settings to that IP address will help me setup separate mail accounts for different domains but have all domains in the same dnn install as parent portals?
Regards,
Karan.
05 Feb 2010 2:29 PM
This article by Power DNN explains how to set it up with Plesk
Karan Jasjit Singh
08 Feb 2010 8:22 AM
Thanks for your answer Lee, I am still waiting for a static IP address from my provider. And then I will try this approach. I would like to know if this can be achieved using DotNetPanel as well? Because if i move to another provider, they are using this control panel, not Plesk.
Thanks in advance.
Karan.
RC-Rob
23 Feb 2010 7:45 PM
Yes, We are running DotNetPanel over at www.resellerchoice.com
Its looks to be much simpler then with Plesk (no dedicated IP's or changes needed), You will be very happy with DotNetPanel over Plesk. Just make sure to select a good host with a proven track record with DNN.
In short, You just add the domains you want your DNN to use to the control panel. In addition you can add any email domains or accounts for Master or Child Portals.
Contact your dotnetpanel host for more details.
Best Of Luck.
Reliable and Fast DotNetNuke Hosting -
Windows VPS Servers -
Windows Dedicated Servers
www.ResellerChoice.com
Forums > Hosting > DotNetNuke® Hosting Providers > Multiple Parent Portals with seperate email accounts on shared hosting
RE: sql script - modify data in a column by Sh@wn
Thank you Mark! I have used this script:ALTER TABLE dbo.C5SLLC_FormData ALTER COLUMN FormData NVARCH...
RE: sql script - modify data in a column by MarkXA
Assuming you're on SQL 2005 or 2008, it sounds like you need to convert the ntext column to nvarchar...
RE: Dl all DNN Videos by greet@fashionchannel21.com
Hello. First of all I need to say that I'm really happy with all the information that I have found o...
this is the error: 'The data types ntext and varchar are incompatible in the equal to operator er...
RE: sql script - modify data in a column by jncraig
What is the error?
hello, I have successfully changed an ModuleID Column with this script: Update dbo.C5SLLC_FormDa...
RE: css class styles by jncraig
I'm afraid that I don't have anything helpful to offer here.
RE: linking to an external resource by jncraig
I think that, as you have discovered, the framework doesn't include that option. One thing that y...
RE: Implementing ISearchable by originator
Hello, Just assign GUID property as follows: SearchItemInfo si = new SearchItemInfo(...) .....
DotNetNuke Nucleus Skin Designer Tutorial - Issue 60 by leesykes
Add any comments or questions regarding the DotNetNuke Nucleus Skin Designer Tutorial from Issue 60
How to use Papayas Auto Upgrade for DotNetNuke - Issue 60 by leesykes
Add any comments or questions regarding the How to use Papayas Auto Upgrade for DotNetNuke tutori...
How to Setup and Use the DotNetNuke Survey Module - Issue 60 by leesykes
Add any comments or questions regarding the How to Setup and Use the DotNetNuke Survey Module tut...
Creating an Events Calendar for DNN using DotNetMushroom RAD - Issue 60 by leesykes
Add any comments or questions regarding the Creating an Events Calendar for DotNetNuke using DotNetM...
RE: Dl all DNN Videos by leesykes
Hello,No I'm afraid there isn't. But you can download all the videos from each issue by visiting eac...
RE: css class styles by cyborama
anyone have anymore insight on this issue with applying contextual background color to the telerik e...
linking to an external resource by cyborama
Hello Lee and Joe, Seems like it should be a no brainer but I am trying to link one of my menu it...
RE: Setting Page Skin by jncraig
The ribbon bar and controls are shown only to users who are logged into your site and given administ...
RE: Changing BG color of solpart sub sub menu ???? by jncraig
You will need to identify the classes assigned to those items and adjust the styles applied to them....
RE: Registered Users by jncraig
As I understand your question, yes.
RE: Admin--> Google Analytics page blank by jncraig
Make sure that you are not in Layout mode.If you are in View Mode or Edit Mode, you might want to ch...
