Subject: best web hosting for dnn sites?
purdyra
06 Jan 2010 8:17 AM
Anyone have any recommendations on who to use or who to stay away from?  Who works well with dnn technologies?
I was thinking about going with ixwebhosting.com.
seems like they get high ratings?
should i only use a windows web host, or unix?
thx for your help?
08 Jan 2010 10:42 AM
Have a look in this section of the forum for feedback on hosting providers:
DotNetNuke® Hosting Providers
I would avoid GoDaddy, a lot of people seem to have problems getting set up with them.
I would look for a hosting provider who has experience with DNN, this will save a lot of headaches in the future for you.
purdyra
08 Jan 2010 10:46 AM
i saw that a few days after i posted this, can you move this post over there?
i ended up going with IXWebhosting and I am still having many problems. This is a real bummer.
08 Jan 2010 10:48 AM
I've moved it.
I personally like Power DNN and Reseller Choice, I have had good support from both of those companies, you will also be able to view feedback on other companies in this forum.
Forums > Hosting > DotNetNuke® Hosting Providers > best web hosting for dnn sites?
That will work.
