Subject: Business & Personal Webhosting Packages.
salmank
16 Dec 2009 1:34 AM
I wonder if someone know from where I can get a business or personal web packages, email packages or domain registration at one place with smart utilities. Hosting Company must be in local Middle East countries. I would appreciate if any one of you could be of my help.
16 Dec 2009 3:32 AM
I moved this thread to the Hosting section as it is not an announcement, hopefully someone may have some experience with hosting in the middle east, thanks,
Forums > Hosting > DotNetNuke® Hosting Providers > Business & Personal Webhosting Packages.
RE: DataSprings Dynamic Forms Demo #20 Question by aggiedan97
Thanks for the feedback. I will let you know what I find and I have posted on the DS forum. So far ...
RE: ITextSharp by leesykes
Glad you got it sorted, what was the solution for anyone else searching for this problem?
RE: DataSprings Dynamic Forms Demo #20 Question by leesykes
Hello,This is not something I have explored yet, but as it happens I am going to be building a form ...
I am attempting to build an order form that subtotals a section that is based on the 'TotalByQuan&nb...
RE: Shared Same content in Sub portals/ Childportals by leesykes
Hello,Your other option is to use RSS feeds for sharing content. Setup a module on your main site su...
RE: Should I be able to use a plain submit button in my module? by DiscoStu1975
Hi I used an ASP:button control originally and that produced exactly the same error with JS disa...
Hmmm, I think that I have seen something like this before, but I'm having trouble remembering the ex...
RE: Shared Same content in Sub portals/ Childportals by jncraig
There are modules available that will permit you to share pages, modules and user among portals in a...
RE: Should I be able to use a plain submit button in my module? by jncraig
Using a form submit button won't work. If you use an ASP:button control that will work as clicking ...
Hi Joseph Thanks for the response. I am using an html input of type submit, yes. When you say a l...
Are you using a form submit button? Try just just using a link and see if that works.
RE: Removing the filed by jncraig
I don't know an easy way to do that, short of editing the ascs file that displays that information. ...
RE: ITextSharp by jumatthey
Problem solved.
Removing the filed by kaustav_kar
Hi,I want to remove the option Display Name from this page. http://whydiet-com.stagemefaster.com/hom...
I have developed a module that is basically a simple data capture form. As I need the form to work w...
RE: Links by rajanijadhav
I have another question,in paypal integration for payment i have used [script removed]
