Subject: DNN4LESS: My best experience
saintX
07 Sep 2009 12:22 AM
I my DNN-Developer life I have got experience with more than 10 hostig providers, from webhost4life to powerdnn and recently with DNN4Less and say by surety that DNN4LESS is the best I have ever experienced.
The most important points for me are:
Performance and speed: I am really impressed! They are the fastest among all.
The support: The most firendly and helpful I have ever experienced. The support team has also helped me to solve the problems professionaly and kindly , even as the cause of error was my own mistake . Actually there weren't any server problems untill now. Everything works perfectly. This is important, that I always can ask them. Never such answers like ask about your problem here and there, what usually powerdnn's support does.
HCP: Very clear and easy to use and covers almost all possible settings of the server.
And as a matter of the course price-performance ratio: $14,99 for 2GB diskspace in comparisson with powerdnn $20 for 1GB.
I am very glad using this server, and recommand them strongly.
Regards, saintX
Rashid Kazi
07 Sep 2009 3:29 AM
Hello SaintX,
Thanks for your kind comments, we always try our best to keep our services at the top level.
We are not pursuing selfish goals or promoting personal advantages at our clients' expense. The fact remains that our future and vested interest is tied directly to your success and your interests. Failing to do just that, we could not expect to work for you tomorrow or ten years down the line. We will make sure our clients are happy with our services.
Rashid Kazi
DNN4Less - Support Department
FREE DotNetNuke Hosting for beginners.
888.523.2360
www.DNN4Less.COM
Thomas McGill
07 Sep 2009 7:10 PM
I agree, saintX, both thumbs up for dnn4less.
Forums > Hosting > DotNetNuke® Hosting Providers > DNN4LESS: My best experience
Community Edition Question by idesofmarch
I've been denied the funds for a Pro edition so I will be using the community edition for a company ...
RE: DNN Site crashed after module install by mcmanta
I found a work around. Looks like the module replaces the Telerik.Web.UI located in the bin folder o...
RE: iHostASP by chandirika
Hi,I am reselling account with this http://www.goresellers.com/ site ,for my web site's web hosting...
the now content not showing and still showing the old one by wael_e
after i uploading the new contenct in my website and i uploading static html page have introdaction ...
RE: Regular Expression by jumatthey
Hi, Thank you very much Mark. It is indeed a name I am checking. Thank you for your help, very mu...
I think this website is properly structured in that I can drop the requirement to exclude certain pa...
RE: Nav Menu v2 for DotNetNuke v5 - Issue 52 by kparker
What are the advantages of setting the RenderMode to UnorderedList for the Nav Menu? How can this b...
RE: DNN Site crashed after module install by jncraig
Most likely, the module that you installed uses a Telerik library that is different from the one tha...
Hello All,I'm using DNN 5.2.3 after install everything was working fine. I installed the 365 Simple ...
Fun? with styling of Home.aspx by dkemp@karrtuttle.com
I asked my assistant to create a page for me and pursue an idea that I had for our intranet.  I thou...
Using Xenu Link Sleuth to Spot and Improve External Links in a Domain by Sh@wn
Hi,I have used this (useful) program in my dnn website and I have seen several page not found errors...
Thanks guys! So what are you using on this site?? Looks pretty much like the standard DNN regist...
RE: Regular Expression by MarkXA
Hi, For the case in point ValidationExpression="^[a-zA-z-' ]*$" should do it. I've added the hyph...
How to slow down the menu by datamark
Can you tell me how to slow down the solpart menu so that the mouse user can be a bit more sloppy ab...
It's a fine line between being too automatic and being too configurable.  It's awesome if Nav 2 indi...
Module Advanced Setting by booth
I need to understand the operation of the “Display Module On All Pages ” control on the setting page...
Efficient Contacts Manager by etadmin
Currently I'm using the Forms and List module, it has about 1500 contacts and 40-50 fields per conta...
RE: How to do links? by leesykes
I think the easiest way to set this up would be to use the default NAV Menu that comes with DNN. It ...
RE: DataSprings / Aweber by leesykes
Yes you probably used an IFrame over a HTML file which included the form, IFrame still exists.Here i...
