Subject: Infuse Web
26 Aug 2005 11:52 AM
http://www.infuseweb.com/
Shared Hosting:
only package which is suitable is level 5, because the other levels do not include a MS SQL database.
Level 5 Paid Monthly
$42.95
Level 5 Paid Quarterly
$122.40
Plan Highlights
Helm Web-Based Control Panel
 1.5 GB (1500 MB) Total Disk Space
50 GB Bandwidth
5 Domains
Unlimited FTP/Secure FTP Accounts
Unlimited POP 3 and Autoresponders
3 Mailing lists with up to 100 Members
Unlimited E-mail Aliases
Unlimited Subdomains
Unlimited Domain Aliases
Catch-All Forwarding
DNS Zone Editor
Password Protected Folders
Virtual Directory Support
ASPJpeg, ASPImage, CFX_Image, ImageMagick Components
CDONTS, CDOSYS Mail Components
ASPUpload Upload Component
ASP, .NET, PHP, Perl, CFMX Support
CFMX Flash Remoting Support
FrontPage 2002 Extensions
Unlimited ODBC DSN's
5 MySQL or Access Database
2 MS SQL Databases
1 Dedicated IP
Custom Error Pages
SmarterStats Detailed Stats Reporting
DotNetNuke (DNN) Ready
Additional Included Features
Virus Scanning on Files and E-Mail
Webmail and Celluar Mail Access
Advanced Anti-Spam Filters
Online Database Management
Comprehensive Tutorials and FAQ
Nightly Server Backups
24x7 Server Monitoring
Unlimited E-mail and Phone Support
30 Day Money Back Guarantee!
They also provide Reseller & Dedicated server hosting
Wylie
16 Feb 2006 8:54 AM
I'm getting first rate service from Infuse Web and only have great things to report.
They have been very responsive to my needs, have helped me set up DNN, consider it a "supported" application and have worked earnestly with me whenever I've had a problem.   They also have posted guidelines on how to install DNN on their servers.  At this time they are not doing an install by request, but will gladly unzip the zip file into a directory of your choice.
I have a reseller account for $45/month.  This allows me 50 domains.  I have two codebases set up and have very successfully configured each one to host multiple portals (about a dozen each at this time).
From my experience the HELM control panel is unparalled in managing your accounts.  It even has ongoing monthly billing options.
Infuse web is not the cheapest, but the servers are not overloaded, you get personal phone and email service, and my applications are always up and responsive.  You get what you pay for.
Chris Wylie
