Subject: PHP, MySQL, Perl, CGI, Ruby.
man3111
15 Sep 2008 5:08 AM
We offer completely ad-free cPanel web hosting. No ads will ever be forced onto our users webpages. There are no catches, no setup fees, no forced advertising, no banners, no popups and no hidden charges. Only totally free hosting service.
Register now, here is what waiting for you:
* 350 MB Disk Space
* 100 GB Data Transfer
* cPanel Control Panel
* Website Builder
* 5 MySQL Databases
* Unrestricted PHP5 support
* Instant Setup!
This service is perfect for starting a new online community, blog or personal website! More info at http://www.000webhost.com/73018.html
Forums > Hosting > DotNetNuke® Hosting Providers > PHP, MySQL, Perl, CGI, Ruby.
