Subject: IX Web Hosting
mortymoose
25 Aug 2008 8:42 AM
Unlimited Pro Plan  14.95/mo
Features*
Unlimited Domains
Unlimited Data Transfer
Unlimited Web Space
3 Free Domain Regs
16 Dedicated IPs
Ecommerce Ready
http://www.ixwebhosting.com/index.php/v2/pages.planUnlimitedPro
~Michael Silva
CornerPixel
www.cornerpixel.net
mortymoose
25 Aug 2008 8:46 AM
Recommended: Yes
Support: Ticket based is good, but 24/7 online chat works best and you get a response right away for most small issues.
Performance: my site is up most of the time.  I haven't had many issues at all.
Value For Money:  Awesome value.  Especially with all the unlimited space and SQL databases.  I am a little worried it is too good to be true, but so far I have 4 DNN sites hosted on one plan.
The one other issue I have had is when I install DNN the last two times I have had the following error.
Installing Database - Version 4.4.0...FAILURE 400 - Thread was being aborted.
I looked on DNN's site and it looks like it is a timeout issue.  The last time I had this issue I just waited until later that night. (6pm PST) and it worked fine.
This time I have a trouble ticket in.
~Michael Silva
CornerPixel
www.cornerpixel.net
Len
12 Sep 2008 1:29 PM
FYI - IX now supports DNN and will install it for you.
Sue Stoos
22 Sep 2008 2:21 PM
Do you find it hard to work with the Sql Server Control Panel?  I have been trying to restore my database after creating a local bak file then ftping it up the the domain, but can't access it.   I tried doing it directly from sql server 2005 but still no luck
Len
05 Feb 2010 9:12 AM
I'm not sure when they started this, but IX now has MyLittleBackup for SQL databases and it seems to work really good so far. http://mlb.ixwebhosting.com
Glad it's working!
Firefox SWF file by ce221
PayFlow Link by murphydolores
