Subject: New Website
arkneth
06 Jun 2008 4:47 AM
My Name is Haitham Nasr, I am from Beirut-Lebanon, I need your advice for the best hosting solution for a new website I am planning to do in the next 7 to 15 days, with DotNetNuke, and this website will include the following:
Big database, the first 6 months can be more than 100M.
Commercial index, the estimated clients 3000, on the first 6 months.
Files will be uploaded from the users on daily basis, word files and small photos.
Too many users (more than 1000) will be online at the same time.
English and Arabic Language will be used on website and the database.
I already downloaded and installed the source package of DotNetNuke on my computer, and make too many changes on it, skins, database tables, and other changes on some modules.
As I mentioned before, it is a new website, we are planning for a good advertising plan for it, and we are expecting 5000 clients throughout the first year.
So advice me for:
The best hosting solution I need.
Is DotNetNuke, a good solution for that website?
Can I upload DotNetNuke that I did in my localhost computer?
Your notes on any other things.
Is it better to make my individual database, other than the DotNetNuke database?
Please take this seriously, as I need to make this site online on the next 7 to 15 days. Moreover, I do not mind if I need to do my work online from the beginning, if this will be better for the website.
Note: I am new on working with DotNetNuke, but I have a good knowledge on working in visual basic 2005, and SQL 2005 server.
Haitham Nasr
06 Jun 2008 6:24 AM
Welcome to the website.
DotNetNuke is a good solution and will be able to handle it easily.
The performance of the DNN install is due to the performance of the server with your hosting provider.
I would have a read of the comments of the various hosting providers in this section of the forum as it should give you a good idea of how other users rate various hosting providers. If you want to compare performance, DNN Creative uses Power DNN
the performance is very good with good support, you can read comments from other powerdnn customers in this forum
Yes you can upload your localhost DNN install to your hosting provider, have a look here:
Hopefully that should get you started along the right path, good luck with your project and if you have any further questions, please feel free to ask as many questions as you need in the DNN Creative forum.
Cheers,
Lee
RE: Expanded sections (Advance settings) collapses automatically! by maxdagenais
Thanks,Yes, I did restart IIS and event the server to make sure but no luck.Again, the issue seems t...
URL Question by bmatthews
Is there a way to make the URLs a little friendly.What I am looking to do is make a page and access ...
Hi Lee, Thanks for getting back to me. Our DNN and portal DBs are 2000 and I did a full backup t...
RE: Upgrade DNN 2.1.2 to use SQL 2k5 by leesykes
Have you tried backing up the SQL 2000 database and then restoring it into the SQL 2005 server?You s...
Oh, and we can't upgrade to a new version of DNN because our custom modules are only for 2.1.2 and i...
Hello,We are currently using SQL Server 2000 with DNN 2.1.2.  We would like to upgrade to SQL Server...
RE: Issue customizing DNN by jncraig
DNN skins for "older" versions should work just fine with 4.9.0.
RE: Issue customizing DNN by leesykes
You could download an earlier version of DNN to get hold of the skin files for DNN Blue, the entropy...
RE: Issue customizing DNN by jberry
The tutorials were very valuable and I am back on track.  In the latest version, the only skin and c...
have you created the username + password access that you specified in the connection string for the ...
. I have access to all folder permissions, and it was working. I just don't enough about the install...
Hello,There is not an easy way to change them to hover over submenu items. When using the house menu...
Thank you both for the replies.  I will get back to the basics here.
RE: How to send mail using the smtp settings by jncraig
I have set up DNN to use a gmail account as the SMTP server. If I remember, you must use xxxx@gmail...
RE: add modules on login and register forms by jncraig
If you login as Host or Admin, you will have a control panel from which you can add modules to pages...
How to send mail using the smtp settings by sherlock005
Hi,I am not able to send the mail.I checked the smtp settings in host settingsi set the smtp server ...
add modules on login and register forms by blanketstream
hi , gaysi have made a site . In skin i was put tag , it is displaying on my pages. when i click on ...
RE: One Year Now, and gladly signing up for a second! by DavidWSnow
A year ago I started this thread and had some very positive comments about DNN Creative Magazine.  M...
RE: Expanded sections (Advance settings) collapses automatically! by jncraig
When generalized behavior like this starts, stopping and restarting IIS sometimes works.
Hi,I apologise for all the happy faces which seemed to have been caused by cutting & Pasting of the ...
