Subject: what moduel do i need
rizwan7705
12 Mar 2008 9:21 PM
can some one help on this please
i m trying to do if users r registering themself  all the information shud be displayed in the other page(new page) automaticly what they put in the registration page. and other people shud be able to search that page and look at it. but shudnt be able to change it
 please help me out lee that ll be great help. i m new to dnn.
 please tell me what moduel do i need thanks
r javed
13 Mar 2008 8:11 AM
Take a look at the Smart-Thinker.com modules.
Forums > DotNetNuke® > Modules - What's needed? > what moduel do i need
RE: Cannot view host filespace using text/html editor by NonStopMark
Hi Joe, The problem has gone away. May have been a caching issue. Thanks for posting. DNN : ht...
Firefox Does Not Display WMV File In Media Module by johnmk777
Hi All,I can't believe I am having such a hard time finding and answer to this question.  I have see...
