Subject: Date time issues
ALEXw
22 Feb 2008 3:31 AM
I've created a modules for an international company which adds tickets(jobs) to a database and gives specific people rights to alter those tickets.
The problem I have is additions of datetime. Every stored procedure (Select, Insert, Update) begins with :-
'SET DATEFORMAT dmy; INSERT INTO......' etc.
All SQLDatasource scripts begin with the same.
If someone adds a record, after clicking the UK locale, he/she can alter the record as many times as they want. If someone attempts to alter that record at a later date using the US locale I get the following error:-
Arithmetic overflow error converting expression to data type datetime. The statement has been terminated.
Can anyone help?
I used to use 'session.LCID = 2057' before I started using DNN, is there something you could recommend?
Every record MUST be added in the UK format. The US mdy or ymd will not be acceptable by the Company because they access the data from differnt software which requires the date to be in the UK format.
PS When populating the formview1 I specify DateTime.now and populating/updating uses the following:-
Public Shared Sub FormViewUpdateEventHandler(ByVal sender As Object, ByVal e As _
System.Web.UI.WebControls.FormViewUpdateEventArgs) _
Handles FormView1.ItemUpdating
e.NewValues("ChangedAt") = DateTime.Now
e.NewValues("ChangedBy") = Entities.Users.UserController.GetCurrentUserInfo.DisplayName
Can anyone help?
Alex
ALEXw
09 Mar 2008 12:30 PM
Dont all rush to reply.....I think I have sorted it anyway as a quick fix.......I just decoded the date and set the DBs date fields to NVarchar. Frigging Microsoft need yo get their finger out of their arse and fix this issue. They have to realise that not everyone comes from the states!!!!!!
If anyone needs to know what I've done....reply....you too can be deafened by silence.
Alex
09 Mar 2008 12:44 PM
Alex,
I'm sorry that we weren't able to help you, but I'm glad that your were able to work around the issue.
