Subject: STORE: product details customization
aliboni
08 Sep 2007 9:15 AM
hi,
i need to customize the store module...
the details of my products contains 4 differents images, a link to a pdf, a link to a .swf in a pop-up and a link for printing the page... so when i add a new product i need to be able to add this content for each product.
i can customize the tamplate .htm but i'm not skilled with the .aspx code)
what do u think? is it too complex?
Forums > DotNetNuke® > Modules - What's needed? > STORE: product details customization
