Subject: Dynamically Change Module Header Text
willydavidjr
09 Aug 2007 6:27 AM
Hi guys,
Is it possible to change the header text of a module without going to host or admin account and change it? I want to change it in my page_load event and other event handlers. Thanks,
Willy David Jr
Forums > DotNetNuke® > Modules - What's needed? > Dynamically Change Module Header Text
