Subject: Events module suggestion
markp
20 Oct 2006 10:10 AM
Events module that a user can submit events (monitored or not) and on the events that are posted by that user, the user would be able to edit /delete the event.  They would have edit abilty on the events that they "own" only.  The administrator role would maintain full edit ability.
Forums > DotNetNuke® > Modules - What's needed? > Events module suggestion
