Subject: music player, music charts
mrvorazan
06 Oct 2008 4:28 AM
hey,
i havev to create a music portal, so i need a module to upload music files by users, they have to be allowed to create their owne albums, have a playlist of the tracs they added to the portal (profile integration),  top-lists: most comment, most viewed, most rated files.
what module u would advice?
bizmodules video gallery is great, but i have a video content on the same portal, so i can't apply it here, cause i can't use different player layouts in one portal
10 Oct 2008 9:42 AM
I have not come across a module which allows this, does anyone else have any suggestions?
carlos183
04 Nov 2008 8:20 PM
I am looking for something similar too. I hope someone creates a module if you find a solution can you let me know too.
Forums > DotNetNuke® > Modules - What's needed? > music player, music charts
