Subject: i need module for display quotes Randomly
smyagnik
06 Aug 2008 9:32 AM
hi
i need a module from which i can display the quotes randomly on all the pages ....
quotes which i add at one time which display randomly
thanks
Satish Yagnik
07 Aug 2008 1:57 PM
I've seen a module that does this. Go to Snowcovered and search for "quotes" and you'll probably find exactly what you need.
Forums > DotNetNuke® > Modules - What's needed? > i need module for display quotes Randomly
