Subject: like a fixed rss url in a rss module.
avilimor1
19 Jul 2006 11:58 AM
Hi!
I am looking for a module in which you'll put it in your site  like a rss reader but it will have already just one xml url.
for example it will be Mr X  daily  blog about whatever he writes.
the idea is that a site admin won't look for a rss over the net to install but he'll look at the dnn modules directory for articles about whatever he likes to put in his site.
Thanks.
Forums > DotNetNuke® > Modules - What's needed? > like a fixed rss url in a rss module.
