Subject: How create Module Definition Upgradeable
xteko
07 Jun 2008 12:19 PM
How create Module Definition Upgradeable, my checkbox Upgradeable is inactive.. How I do?
07 Jun 2008 11:31 PM
I believe that the module must implement the Iupgradable interface.
Forums > DotNetNuke® > Modules - What's needed? > How create Module Definition Upgradeable
