Subject: How to integrate DNN with OAI-MPH to implement
cvirom
04 Jun 2008 9:18 AM
Can any one please tell me if there is a module that
implements the OAI-MPH standard with multiple DNN sites.
I have only found OAI-MPH implementations based on LAMP
(Linux-Apache-mysql-PHP), but I am interested in a Windows
solutions: IIS + MS SQL + .Net
Thanks for your time.
Best regards, Carlos
04 Jun 2008 7:16 PM
I had to Google OAI-MPH, and I still have to read to understand what it really is ...
So I guess that I'm not aware of a module. But if you can do it with XML/XSL, then you could use the UDT module ...
Forums > DotNetNuke® > Modules - What's needed? > How to integrate DNN with OAI-MPH to implement
