Subject: UDT Module advanced search capability
WSI
19 May 2008 10:23 AM
With the User Defined Tables Module ... is there a way to say allow my users to search by "Lastname" and "zip code"?  I type in a Lastname in one box, zip code in another then hit search.
Dave
Nuke Master I
Nuke Master I
19 May 2008 11:13 PM
The answer I read from Sebastian Leupold is that you can't do this with the current version of the module.
Forums > DotNetNuke® > Modules - What's needed? > UDT Module advanced search capability
Missing subscriber access by stefanheskjaer
I subscribed on 07-01-2008 and received my confirmation from PayPal. Still unable to access the vid...
Define Style by Vereen84
A style sheet is a free-flowing document that can either be referenced by, or included into a HTML d...
Tell a Distribution List Module by greenglow
We're looking for a DNN Tell a Friend module that allows people to forward the page to a distributio...
XML settings for Feedback Module by saintX
Hello,I don't want the help (blue question marks) to be dispalayed besides the fields of the feed ba...
shadowmu by gunitshadow
Server Info:XP: 100xDB: FreshDrop: 85%Version: S3 Episode1 PremiumShops: FULLSpots: FULLUptime: 24/7...
RE: Calendar Strobe? by leesykes
Hello,Welcome to th forum, when I hover over a link in IE7, IE6 they display just the same as FF2 - ...
RE: Custom HTML Skin - link module center overridden with left align by leesykes
Not sure what is happening here, I tested again in FF2 in view mode and the links are centered.I hav...
RE: HouseMenu doesnt work by leesykes
Hello,Check out this forum post for some quick tips with HouseMenu
RE: Issue 34 New Skins and House Menu by leesykes
RE: Open menu links in new window? by leesykes
Hello,If you attach the code in a zip file to your forum post we can have a look, thanks,
RE: File Manager with Limited Access by leesykes
Hello,I have just tested this and have the same problem. Perhaps it would be worth looking for docum...
RE: how to develop skins in dotnetnuke by leesykes
Hello,If you go to the main tutorials page and scroll to the bottom you will see a big list of skinn...
RE: deploy developed wedsite by leesykes
Hello,You may find these tutorials useful,How to transfer a localhost DotNetNuke installation to a l...
RE: Please help me in choosing web hosting by leesykes
I would recommend you view the comments on hosting providers in the hosting section of this forumI w...
RE: Is posible creating multiple website (portal) in a single DNN installation? by leesykes
You can do that approach, if it is a localhost installation, you may find it quicker to create child...
how to develop skins in dotnetnuke by rao_babu24
how to develope skins for dotnetnuke  thanks advance
deploy developed wedsite by rao_babu24
how to  deploy developed wedsite thanks advane
Please help me in choosing web hosting by 0xyGen
Hi everyone,I am sorry for possible offtopic, but I need your help in find new web hosting provider ...
RE: Is posible creating multiple website (portal) in a single DNN installation? by aravinthkula
Thanks for your reply. Actually we followed a approach like created different portal like portal1 a...
File Manager with Limited Access by tds_softwaredev
Hi Everyone, I was hoping someone might have a solution for a little problem I have run into. I w...
