Subject: UDT Module advanced search capability
WSI
19 May 2008 10:23 AM
With the User Defined Tables Module ... is there a way to say allow my users to search by "Lastname" and "zip code"?  I type in a Lastname in one box, zip code in another then hit search.
Dave
19 May 2008 11:13 PM
The answer I read from Sebastian Leupold is that you can't do this with the current version of the module.
Forums > DotNetNuke® > Modules - What's needed? > UDT Module advanced search capability
