Subject: How to upgrade core module?
LeeWebDev
17 Mar 2010 8:32 AM
I can't believe this is so hard to find instructions for, but how do I upgrade to the latest version of a particular core module? Specifically, the Events module. I downloaded the latest version (5.00.03) zip file from CodePlex. Now what?
David
17 Mar 2010 10:04 AM
All you need to do is install the downloaded core module in exactly the same way as you would install a new third party module. DotNetNuke will then upgrade the module.
Make sure that the latest version of the core module is compatible with the DotNetNuke version you are running.
I would suggest you backup your website and database before upgrading any modules just incase any data is lost.
How to install a Module in DotNetNuke 5
LeeWebDev
18 Mar 2010 8:29 AM
Forums > DotNetNuke® > Modules > How to upgrade core module?
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
