Subject: DNN Site crashed after module install
mcmanta
15 Mar 2010 6:53 PM
Hello All,
I'm using DNN 5.2.3 after install everything was working fine. I installed the 365 Simple Flash Navigator -- Super Simple Flash Image Rotator I received a successful install message. Once I reloaded the web page I received the Telerik error message below.
FileLoadException: Could not load file or assembly 'Telerik.Web.UI' or one of its dependencies.
The located assembly's manifest definition does not match the assembly reference.
Tom
15 Mar 2010 9:46 PM
Most likely, the module that you installed uses a Telerik library that is different from the one that comes with DotNetNuke. Since the use of Telerik modules is new inDotNetNuke, this may mean that you need an upgrade of the module. Get in touch with the module developer and see if they can help you.
mcmanta
16 Mar 2010 9:34 AM
I found a work around. Looks like the module replaces the Telerik.Web.UI located in the bin folder of my DNN 5.2.3 install. I guess this version is out dated. I downloaded a fresh copy of DNN 5.2.3 and copied the Telerik.Web.UI from the bin folder and replaced the one on my site and I'm back online. I'm still trying to get in touch with the module developer to get a newer version. Thanks for the quick reply Joe!
Forums > DotNetNuke® > Modules > DNN Site crashed after module install
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
