Subject: Module Advanced Setting
booth
15 Mar 2010 12:24 PM
I need to understand the operation of the “Display Module On All Pages ” control on the setting page of the Text/Html Module.
I place a module on my home page and checked the Display Module On All Pages ” check box.  The module then appeared on all pages.
I modified the module  le and that propagated to all the pages.
I modified the Allow Print and Display container controls in the Page Settings on the Home page module and they did not propagate to the other pages.
How can I get changes made on the Home Page version of the module to tale effect on all the pages.
16 Mar 2010 3:48 PM
The module contents is distinct and separate from the Module's container on a particular page.
When you set a module to appear on all pages, it will appear but it will use the default container and module settings for the page. This is by design, so that a page style can be maintained. The Print and other module settings belong to the page, not with the module.
Forums > DotNetNuke® > Modules > Module Advanced Setting
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
DNN Creative Subscribe
