Subject: OWS Query Template Results
Vicky Swift
05 Mar 2010 6:24 AM
Hi I'm a real newbie at OWS and have been working through the tutorials - I felt confident to have a go myself but have got really stuck on something that I am sure is trivial / obvious. I have a Query template with the following SQL statement on it SELECT FieldTitle,FieldValue,UserDefinedRowID FROM UserDefinedData JOIN UserDefinedFields ON UserDefinedData.UserDefinedFieldID = UserDefinedFields.UserDefinedFieldID WHERE UserDefinedRowID IN (SELECT UserDefinedRowID FROM UserDefinedData JOIN UserDefinedFields ON UserDefinedData.UserDefinedFieldID = UserDefinedFields.UserDefinedFieldID WHERE UserDefinedRowID IN (SELECT UserDefinedRowID FROM UserDefinedData JOIN UserDefinedFields ON UserDefinedData.UserDefinedFieldID = UserDefinedFields.UserDefinedFieldID WHERE FieldTitle = 'Non' AND cast(FieldValue as nvarchar(max)) = 'True' ) AND (FieldTitle = 'MI' AND cast(FieldValue as nvarchar(max)) = 'True') ) AND (FieldTitle = 'Name' OR FieldTitle = 'Link' OR FieldTitle = 'Notes') ORDER BY UserDefinedRowID I then display the results from this using a detail template
[FieldValue]
This works fine. Now I would like to manipulate the way the data is displayed. So for example take the [FieldValue] from several rows of data and display these in one row in the detail template. I have spent a lot of time trying to do this and am going around in circles - can anyone help Thank you
KA-NA
11 Mar 2010 2:07 AM
I don't know, that is possible, but I would try to use javascript in dteial template to build string and then use it in footer template.
Vicky Swift
11 Mar 2010 3:07 AM
Hi, In the end I achieved what I needed with IIF statments and ALTERNATE Pretty sure its not the neatest solution - but it does what I need.
Forums > DotNetNuke® > Modules > OWS Query Template Results
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
