Subject: HTML/Text Custom templates
gerry
02 Jan 2010 6:32 PM
I notice the html/text module can insert templates. Can these be customized or add new ones? Also could you restrict which templease are available to the user?
Regards - Gerry
02 Jan 2010 8:48 PM
You can create page and portal templates in DotNetNuke.  See:
DotNetNuke Portal Templates and the Site Wizard
Configuring DotNetNuke before installation
(How to create a portal site template for the wizard)
The Text/HTML module doesn't use templates.  However, you can export a module's contents and import it into another Text/HTML module.
gerry
02 Jan 2010 9:12 PM
Thanks for the reply. Maybe I was unclear.
The third icon in the fckeditor has a button for inserting templates into the HTML/Text module
It is these templates I want to modify or limit
Regards - Gerry
02 Jan 2010 9:24 PM
Aha!  Look at this:  FCK Editor HTML Templates
gerry
02 Jan 2010 9:30 PM
Perfect, was using wrong search term and abit lazy to scroll through all the results due to the festive season!
Regards - Gerry
02 Jan 2010 9:35 PM
No problem.  Enjoy the festivities!
gbrown
03 Jan 2010 12:00 PM
The templates feature can be very handy and useful. I switched to Telerik's RADEditor mainly for it's very nice templates manager. It is much nicer than FCK's where FCK just has a single list that is the same on all pages in your portal. RAD has a templates manager much like the image manager in FCK where you can place templates in folders and control access to different types of templates.
Forums > DotNetNuke® > Modules > HTML/Text Custom templates
RE: HTML module not updating after transfer from localhost to live server by chrisoc
Hey guys,Thanks for the replies.   All seems to be working fine now.  I had previously cleared the b...
RE: w2k8 r2 - dnn site visible locally but not from internet by guyperrin
thanx joe. i just kept slugging away at this one. finally, when i gave IIS_IUSRS Full Control, i w...
RE: HTML module not updating after transfer from localhost to live server by jncraig
Check to make sure that you adjusted your portalalias table to point to the live site. It's possibl...
RE: w2k8 r2 - dnn site visible locally but not from internet by jncraig
Check to make sure that DNS points the site's URL to the web directory.  Your host ought to be able ...
RE: user retrieve password by giving email by jncraig
That should work. As with most things like this, I would recommend that you test and verify this ...
RE: Creating a new user by jncraig
DotNetNuke uses the ASP.NET membership scheme. I haven't tested, but I am reasonably surethat the s...
RE: Email Verification by jncraig
Is this a question about Dynamic Forms? You can use Regular Expression validation to force the us...
RE: Issue 33 SQL updating page settings by jncraig
Can you describe the problem a bit more?
user retrieve password by giving email by raf948
I am using 4.8.0  and would like to have users retrieve password by giving their email ( as I unders...
RE: Change linkclick to document name by WinXnet
as far as I know, there is no way to not use linkclick other than to hard code the long url Selec...
RE: Skin missing banner and menu when ctl is used in the url by WinXnet
you're site appears to be down...
RE: DNN Live site not displaying by WinXnet
Is your site Properties in IIS > Documents > Enable default content page set to "Default.aspx"? E...
What version of DNN? Emerson ^_^
RE: Cross Portal Admins by WinXnet
Sorry for this post ^_^ My error - I got the password for the user wrong. Create user account ...
The menu is a module and it is set to publish on all pages. The HTML module is not set to publish t...
I have  situation where admins want to use the same login/password across multiple parent DNN portal...
RE: Issue 33 SQL updating page settings by pedrocapetillo
I have i similar problem and i am using DNN360 menu. Does anybody have information about that? Be...
Store module just refreshes page on "confirm order" by mike.hassinger
I have set up the store module with an Authorize.net account, set for authorize + capture. The check...
RE: logo token not functioning by WinXnet
I'm sure you've done this, but be sure you click on the "upload selected file" link under the Browse...
Is your menu a module as well? Is your banner HTML module set to "publish on all pages", or is it...
