Subject: Orizonti vs. Novus ?
tcse
25 Dec 2009 9:01 AM
Hello Lee, Great tutorial on setting up and using Orizonti, I went to snowcovered.com and started looking at other RSS feed readers and also found "Novus" by "OnyakTech" Novus seems to be pretty nice module also, just wondering if you have tested it also. On the demo site www.NewVus.com they are pulling in RSS feeds from DNNCreative, so I wasn't sure if you had tested w/ this mod or not? Also by looking at www.Orizonti.com website there has not been a product update since march of 2006. Are they still in business, or is the Orizonti Module just that Darned Good!
gbrown
27 Dec 2009 11:36 AM
I have the Orizonti RSS module. I also have the Xmod RSS module.
But I think the best RSS module is now the News Article module from Ventrian. They added the ability to import RSS feeds about a month ago. Very cool - everything is templateable, your users can add comments to each RSS article, you can mix RSS articles with your local site articles/announcements, the News Articles module imports RSS articles to a table in your database and the import runs off of the DNN scheduler so RSS feeds should run much faster than the traditional method, etc.
Forums > DotNetNuke® > Modules > Orizonti vs. Novus ?
That will work.
RE: PayFlow Link by johnmurphy
Hi murphydolores, I am using iHost. iHost.Net supports PayFlow Link and its easy to configure. T...
RE: Background Music by cyborama
Hello Kyle I can't think of any modules that could do this though that doesn't mean they are not out...
Hello Joe thanks for the quick reply, If you read down my thread fully you will see I had already...
