Subject: Anybody use Smith Cart?
JacobBushnell
11 Dec 2009 1:40 PM
Hello, after months of searching I started using AliCommerce shopping cart with good success. No unfortunately I found I was duped into buying pirated software. :GRR: http://www.bvsoftware.com/alicommerce/default.aspx Any way, so now the seach continues as the "maker" of AliCommerece hasn't made a DNN version yet. I have been looking at Smith Cart made by smith consulting. Does anybody have any experience using this cart? http://www.smith-consulting.com/products/dotnetnukemodules/shoppingcartmodule.aspx Thank you, Jacob Bushnell
bschwartz215
18 Dec 2009 8:51 PM
I am trying to find out as well. I have looked at several dnn store modules, including the dnn core store module. I am not sure whether to use the core module, or pay for a module that may be better. If you hear anything, can you pass the info on to me? It would be greatly appreciated.
bill
08 Jan 2010 6:12 PM
There's a good thread I was reading a couple months ago on another forum/blog. The thread has a lot of info on store modules for DNN. I'll try to find it again.
09 Jan 2010 9:28 AM
Are you referring to comments on Tom Kraak's blog at seablick.com?  It's a blog entry about ecommerce.
bill
11 Jan 2010 9:39 AM
Yes, I think that's the one.
Forums > DotNetNuke® > Modules > Anybody use Smith Cart?
Should I be able to use a plain submit button in my module? by DiscoStu1975
I have developed a module that is basically a simple data capture form. As I need the form to work w...
RE: Links by rajanijadhav
I have another question,in paypal integration for payment i have used [script removed]
Shared Same content in Sub portals/ Childportals by carlliw
Hello,I have a DNN parent portal and about 35 child/subportals. There are about 5 pages in all 35 c...
RE: Car Auction Book - site. by ollep
Hi again Lee!! Just started reading a bit on the Tutorial, after playing with AWeber and instal...
I don't think it's a skin issue. I have tried changing to DNN default skin and the problem remains. ...
Good morning sir. I want to rename the my parent portal from 'golden.s20.dotnetsql.com' to 'webstor...
Thanks for all the good ideas Lee, much appreciated. As to One Life International your book sho...
Is this site using a custom skin?
RE: Permissions Question by BCRose
OK thanks...I will not mess with this.
RE: Permissions Question by jncraig
It would be pretty close to that, yes. You would remove the controls that provide the functions tha...
RE: Vacation Rentals by joeleitz
That lodgeaway site is pretty nice and I especially like the photo that comes up when you first go t...
Could I just delete the parts that refer to User Settings and Profile Properties and save it with a ...
No, it would not involve editing the source code. But ... it would involve taking parts of the so...
Does that involve editing the source code? May not be too big of a challenge to you but that is som...
Is this fixed now?
Well, thinking about it ... it would not be too big of a challenge to take the module, remove the fe...
Ummm...too bad. That seems like a no-brainer for this module.
I don't believe that's possible. I'd love to learn that I'm wrong.
Ok, Thanks for the info. I was able to make those changes, Now...I want this user to be able to ad...
In DotNetNuke 5.x, you have control of permissions on the Admin and Host pages. So, you can grant p...
