Subject: Custom Register Page
Steve
03 Dec 2009 1:21 PM
Hi, I'm trying to set up a custom register page but I don't seem to have the User Account module. Ive got the latest DNN installed. Any info appreciated. Thanks
04 Dec 2009 8:41 AM
For me, it is "Account Login" and is the first module that appears on the dropdown list.
Steve
05 Dec 2009 7:38 PM
Thanks for the reply. I seem to have found my problem. I read an earlier post about customizing the Register page by creating a new page and adding the 'User Account' module, and telling your site that's where the new Register page is. But in my version of DNN, there is no 'User Account' module, its called 'Users and Roles' and has a couple extra things as well as the User Account.
05 Dec 2009 8:07 PM
05 Dec 2009 8:40 PM
I'll answer my question with a guess.  You are using Version 5.x of DotNetNuke.
And, yes, that is the module.
Forums > DotNetNuke® > Modules > Custom Register Page
RE: How to Create an Email Form with OWS - Issue 49 by CelesteT
Hi, Was also wondering if there was a way to incorporate ReCaptcha (www.recaptcha.net) into the emai...
Hi, Thanks for the great tutorial. I was wondering how I can hard code a "to" email address into th...
That will work.
DNN Creative Subscribe
